pop goes the motor
Discuss any information on turbo charging or super charging the RX8.
Moderator: zoom
donger
Re: pop goes the motor
Post by donger » Sat Nov 26, 2016 7:52 pm
engine is back together now ,have got a new mount made to suit (steel) able to use standard mount now not one that has the wing(support) cut off and the pins ground away for the waste gate mount/engine mount. All of the braided lines that where added in the turbo upgrade have been changed to steel lines ,they got to hot and became weak!
donger
Post by donger » Sun Dec 18, 2016 10:21 am
engine run in finished now , water/meth injection to be fitted then I can increase the boost/fuel amount.
donger
Post by donger » Thu Mar 30, 2017 3:51 pm
water / meth injection is installed now , just waiting on my micotech ecu to be fixed,it has lost a channel. I have increased my redline to 10800 rpm with the versatune program .
Txateu
Post by Txateu » Fri Mar 31, 2017 8:03 am
10.8k rpm Would sound amazing, are you still using genesis rotors or did you change to a low compression rotor?
donger
Post by donger » Fri Mar 31, 2017 2:13 pm
I put in racingbeat rotors, they are the lighten and balanced ones for boosted rx8, not cheap!!! they are good for 11300rpm.
donger
Post by donger » Tue Oct 03, 2017 9:23 pm
just got my car back today , it revs to 10000rpm on 14psi boost, ended up changing my seals to psycho seals , will dyno soon!
zoom
Post WHORE!
Post WHORE!
Post by zoom » Wed Oct 04, 2017 9:09 pm
donger wrote:just got my car back today , it revs to 10000rpm on 14psi boost, ended up changing my seals to psycho seals , will dyno soon!
Curious for the dyno. HP and Torque curve above 7500 mostly.
Mazda RX8 Club Australia | Winton: 1:42.86 | Sandown: 1:32.42 | Broadford: 1:10.45 | Wakefield: 1:15.94
skc
Contact:
Post by skc » Fri Oct 06, 2017 2:09 pm
Nice upgrades. With 14psi you should have around 260kw at the wheels?
skc
Hymee Supercharged (200kw at the wheels)
Lakeside 1:02.02
Wakefield 1:12.04(NA) 1:11.36(FI)
donger
Post by donger » Tue Nov 28, 2017 7:27 pm
i have changed my secondary injectors to 1500cc ,it was to lean before, the power curve dropped at 9000 rpm , i was not told how much hp etc only where the curve dropped away , it should be tuned soon.
donger
Post by donger » Sat Apr 21, 2018 9:53 pm
has anyone else had a problem with there high flow cat ? I have now broken /melted for the second time !
zoom
Post WHORE!
Post WHORE!
Post by zoom » Sun Apr 22, 2018 8:53 pm
donger wrote:has anyone else had a problem with there high flow cat ? I have now broken /melted for the second time !
I had an issue where I was running lean which destroyed 2 cats. But that was a mix of lean running for long times under harsh conditions and cheap cats not intended for the purpose.
What cat are you using?
donger
Post by donger » Sun Apr 22, 2018 9:54 pm
I don't know , first one added by promaz,then second fitted when engine rebuild,it was a lean tune as well,one was rolled seams and the other welded. what brand are you running?
zoom
Post WHORE!
Post WHORE!
Post by zoom » Mon Apr 30, 2018 1:15 pm
donger wrote:I don't know , first one added by promaz,then second fitted when engine rebuild,it was a lean tune as well,one was rolled seams and the other welded. what brand are you running?
Magnaflow. They have a specific high heat one supposedly.
donger
Post by donger » Tue May 08, 2018 8:14 pm
car is back, it is a different drive now ,ended up getting a new cat that has a bigger body diameter to spread the heat better 3"in 5"body 3"out. Boost is set to 14 PSI .
