pop goes the motor
Discuss any information on turbo charging or super charging the RX8.
donger
pop goes the motor
Post by donger » Sun May 22, 2016 2:14 pm
my motor has giving up the ghost , only 1 chamber left working on rear ! over boosted ! Time to rebuild it stronger,new rotors that are made to handle 20 psi boost, the aim is to get over 400 horsepower at the wheels , 300HP was getting boring !!
Re: pop goes the motor
Post by tim33h » Mon May 23, 2016 1:38 pm
Who's doing he work for u mate??
Sent from my iPhone using Tapatalk
donger
Post by donger » Mon May 23, 2016 4:49 pm
getting Andrew from brookvale to do it
Post by tim33h » Wed May 25, 2016 6:40 pm
What workshop is that matey??
donger
Post by donger » Wed May 25, 2016 7:24 pm
Brookvale mechanical and exhausts, Andrew has been building rotories for for a long time on the northern beaches,plus he is a 5 minute walk from where I live. He done the bump compression test for me , engine should be out and open before the end of the week hopefully.
JinkoMK
Post by JinkoMK » Thu May 26, 2016 6:43 pm
20PSI on a Renesis... Godspeed my friend.
donger
Post by donger » Fri May 27, 2016 9:29 pm
you should all ways rebuild stronger , and hope it last longer! I only had a stock engine before on 10 psi.
donger
Post by donger » Fri Jun 03, 2016 11:12 pm
got a MRT boost controller today . up to 6 different boost setting .
donger
Post by donger » Fri Jun 10, 2016 3:53 pm
my engine is getting dropped out tonight ! I have broken my cat as well from the over boost, now I wish I had a boost gauge before it blew up!!!
Mazda Sports Corner
Post by Mazda Sports Corner » Fri Jun 10, 2016 8:46 pm
What are you going to do to the motor so it can that sort of boost?
donger
Post by donger » Fri Jun 10, 2016 9:09 pm
lower compression rx8 rotors from usa.
Mazda Sports Corner
Post by Mazda Sports Corner » Sat Jun 11, 2016 1:13 pm
Who does those? what Apex seals do you use with them?
donger
Post by donger » Sat Jun 11, 2016 4:09 pm
racing beat do a lightened rx8 rotor assembly but i don't know which seals yet to use with them. my engine man knows what he wants to use,will tell when i know the answer.
donger
Post by donger » Tue Jun 14, 2016 10:24 pm
motor is open , I need 2 housing's and 2 rotors , rear housing has a big gouge out of it from broken seal . front had uneven wear. The mount for the turbo is all bent out of shape!
Mazda Sports Corner
Post by Mazda Sports Corner » Wed Jun 15, 2016 8:29 pm
post some pictures if you can.
