RX8Club SA Dyno Day - Southern HiTech Dyno 29/09
Regional Forum for all in SA
Ripper.
Re: RX8Club SA Dyno Day - Southern HiTech Dyno 29/09
Post by Ripper. » Tue Oct 02, 2012 10:43 pm
Sorry to hear the bad news man. It may be worth stretching the budget and getting it sorted sooner rather than later if it's an option?
Otherwise baby it, and save as quick as you can!
dcer10 wrote:I'm certainly not an expert, but this guy is saying (for an RX7) that 85psi is a good pressure when the engine is ok.
Yeah, they're not referring to our engines though. The 13B-MSP has higher compression than the 13B-REW (10.0:1 vs 9.0:1)
Mr_Porter wrote:For what Jase was saying 120 is like top what you would get form a new engine and 80 is rebuild time good as dead, and yeah i think it must be in psi.
Mazda wrote:Compression pressure
• Standard: 830 kPa {8.5 kgf/cm2, 120 psi} [250 rpm]
• Minimum: 680 kPa {6.9 kgf/cm2, 98.6 psi} [250 rpm]
• Difference in chambers: Within 150 kPa {1.5 kgf/cm2, 21.8 psi}
• Difference in rotors: Within 100 kPa {1.0 kgf/cm2, 14.5 psi}
hellaflush
Post by hellaflush » Tue Oct 02, 2012 11:32 pm
Yup... 90's is definitely on the low side... you're only several PSI away from dipping into the 80's which will be a seal failure...
Put it into perspective... 120psi is freshly built engine... you're 26-29psi away from that... 80 is a dead seal... you're only 14 to 11 away from that!
Start saving your pennies porter... you'll be very happy when you have a fresh engine with a mild street port in it! (you'll be making more power than all of us...) well except for when I have my bridgeport done ;)
05' S1 RX8 Luxury
Cobb AccessPort Computer + MM Tune, Optima Redtop Battery, BHR Ignition Kit, BHR Flywheel + Counterweight, SS Clutch line, ACT HDSS Clutch, Knightsports 2nd Oil Cooler,
REmedy Water Pump, REmedy Thermostat, RMagic Solid Rear Cradle Bushes, Bride Zeta III FRP Fixed Back,
BC HR Coilovers, Exhaust Technology 3" Mild Steel Resonated 6" Rotaflo Midpipe, Exhaust Technology 3" Mild Steel Single Exit Rotaflo Catback, DBA-5000 2 Piece Slotted Rotors, Project MU BSpec Pads
Rays TE37 18x9.5 +12 in Gunmetallic Fleck with 225/40/18 and 245/40/18 Federal 595SS, Project Kics Titanium Extended Lug Nuts
129RWKW on BP98 Pump
spinner
Post by spinner » Tue Oct 02, 2012 11:37 pm
Compression is related to rpm so your figures need rpm to make sense
"The ingenious and decidedly weird Wankel rotary engine works by using internal combustion to bounce a fat metal triangle around inside a hollow metal kidney bean, which hula-hoops around a central shaft to generate power"
[D]
Post by [D] » Tue Oct 02, 2012 11:47 pm
What kind of symptoms were you experiencing on the day Porter? The usual ones?
Sorry to hear about the issues mate, kinda makes me nervous now :?
Hope it all works out for you
2005 NC1 Brilliant Black MX5 Limited Edition (Manual)
2004 S1 Velocity Red RX8 Luxury (Auto) - SOLD :cry:
Mr_Porter
Post by Mr_Porter » Wed Oct 03, 2012 11:08 am
spinner wrote:Compression is related to rpm so your figures need rpm to make sense
250 RPM
Post by tim33h » Wed Oct 03, 2012 2:13 pm
What can u do in the meantime? Run a thicker oil? 20w-50 or something?
Mr_Porter
Post by Mr_Porter » Sat Oct 13, 2012 12:53 pm
Update on my car.
So i got the fuel pump replaced but still having the same issues AFR is running in the 14's.
CAT looks ok apparently, going to have a like into re-flashing the ECU next.
Kevs_8
Post by Kevs_8 » Sat Oct 13, 2012 1:57 pm
Did you check the fuel filter? John thought it was worth a try.
Aluminium metallic RX8GT S2
hellaflush
Post by hellaflush » Sun Oct 14, 2012 12:32 am
leaky or clogged injector?
05' S1 RX8 Luxury
