Is Mildrens still in business?
Is Mildren's Automotive still in business?
I just rang their number and got diverted to another workshop ?!?!?
In any case, got a quote from Jason in REVS tho... so it's not like there's no one to service the car...
just odd. that all.
anyone knows?
C
just odd. that all.
anyone knows?
C
Re: Is Mildrens still in business?
Nvm read in another post that absolutewankel had the same episode.
Going to book it into revs
Fixed.calvinp wrote:Going to book it into revs for the turbo conversion.
- Validated Member
Tell jase i sent you - this goes to any RX8 club members
05' S1 RX8 Luxury
Cobb AccessPort Computer + MM Tune, Optima Redtop Battery, BHR Ignition Kit, BHR Flywheel + Counterweight, SS Clutch line, ACT HDSS Clutch, Knightsports 2nd Oil Cooler,
REmedy Water Pump, REmedy Thermostat, RMagic Solid Rear Cradle Bushes, Bride Zeta III FRP Fixed Back,
BC HR Coilovers, Exhaust Technology 3" Mild Steel Resonated 6" Rotaflo Midpipe, Exhaust Technology 3" Mild Steel Single Exit Rotaflo Catback, DBA-5000 2 Piece Slotted Rotors, Project MU BSpec Pads
Rays TE37 18x9.5 +12 in Gunmetallic Fleck with 225/40/18 and 245/40/18 Federal 595SS, Project Kics Titanium Extended Lug Nuts
129RWKW on BP98 Pump
from what i understand mildrens closed its doors and revs has expanded..
- absolutewankel
Yep. Someone has taken over the phone number for mildrens but they aren't mildrens. Seems dodgy to me hence the preference to drive an hour out of my way to get the job done by someone trustworthy (revs).
If anyone else has anything to say in the new company's defence I would like to hear. What happened to Greg anyway?
Series II RX-8 - completely factory.... will get around to changing that soon!
Greg's closed the place at Thebarton, did do a rebuild for me a few months ago, so still doing work for the dealers.
Cheers Shane
Cheers Shane
- Little Brapper
- Contact:
Mods:
Bridgeport secondaries and aux ports
Early model housings, pp exhaust ports, side exhaust ports blocked off
5.12 diff
Pmu replacement pads and discs
Whiteline rear sway bar
Superpro front sway bar
Offset camber bushes in front control arms
18x9 Enkei PF01
5.12 diff
18x9 Enkei PF01
- Little Brapper
- Contact:
Greg is still around. Purchased my rotaflow parts off him.
Mods:
5.12 diff
18x9 Enkei PF01
5.12 diff
18x9 Enkei PF01
