It is currently Wed Oct 18, 2017 6:25 pm
Post new topic Reply to topic  [ 5 posts ]
Author Message
 Post subject: Clutch question?
PostPosted: Thu Aug 10, 2017 6:23 pm
Offline
Today my RX8 out of nowhere at the lights almost completely stopped allowing me to select first gear from a standing start and 2nd and 3rd gears sort of grind into gear. 1st crunches like the clutch isn't properly depressed (when fully depressed).
Noob question of the day... is this an indication of my clutch being worn out or a gearbox issue?
Sent from my SM-G930F using Tapatalk
Top
 Profile
 Post subject: Re: Clutch question?
PostPosted: Thu Aug 10, 2017 7:53 pm
Offline
Check ur clutch master and slave cylinder.
Sounds like it may have a pressure issue.
I have an 07 and just recently got breaks and clutch fluid changed as clutch was a bit spongy.
It feels totally different now as probably never changed by previous owner for the clutch, ive only done the breaks a couple of times. Make sure the slave cylinder gets bled through. Good luck and hope it's only needing new fluid.
Top
 Profile
PostPosted: Fri Aug 11, 2017 12:49 am
Offline
Thanks mate. I'll check that cheers
Top
 Profile
PostPosted: Tue Aug 15, 2017 10:05 pm
Offline
Matt13b if you are replacing your clutch you can pickup the blackhalo lightweight flywheel on the weekend.
Top
 Profile
PostPosted: Wed Aug 16, 2017 4:24 pm
Offline
That would be awesome tbank you
Top
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 2 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB® Forum Software © phpBB Group
