Cruise 24th February
Regional Forum for all in SA
Kusanagi8
Re: Cruise 24th February
Post by Kusanagi8 » Thu Feb 21, 2013 9:22 am
I think I should be able to make it.
Ripper.
Post by Ripper. » Thu Feb 21, 2013 9:49 am
Good to hear Ket.
Ripper.
Post by Ripper. » Fri Feb 22, 2013 3:32 pm
List in opening post updated. :wink:
calvinp
Post by calvinp » Sat Feb 23, 2013 4:16 pm
Soz guys.
I will have to sit this one out.
Until I can ascertain if my cooling system is indeed operating within normal parameters, I don't think I'd want to risk extended temperatures above 105 deg for fear of doing irreparable damage to the engine :P
I will be booking her in for a thorough once over at the earliest opportunity with a rotary mechanic.
regards
C
Kevs_8
Post by Kevs_8 » Sat Feb 23, 2013 5:33 pm
Looks like I'm going :D
Too bad about the cooling system Calvin. Your car hasn't done that many kms.
Aluminium metallic RX8GT S2
Ripper.
Post by Ripper. » Sat Feb 23, 2013 5:56 pm
calvinp wrote:Until I can ascertain if my cooling system is indeed operating within normal parameters, I don't think I'd want to risk extended temperatures above 105 deg for fear of doing irreparable damage to the engine :P
I'll go for a spin in a minute and let you know what temp I get up to. :D
I'm pretty sure mine regularly goes over 100C.
hellaflush
Post by hellaflush » Sat Feb 23, 2013 6:25 pm
highest mine has gotten is 91c... generally sits between 83-86
05' S1 RX8 Luxury
Cobb AccessPort Computer + MM Tune, Optima Redtop Battery, BHR Ignition Kit, BHR Flywheel + Counterweight, SS Clutch line, ACT HDSS Clutch, Knightsports 2nd Oil Cooler,
REmedy Water Pump, REmedy Thermostat, RMagic Solid Rear Cradle Bushes, Bride Zeta III FRP Fixed Back,
BC HR Coilovers, Exhaust Technology 3" Mild Steel Resonated 6" Rotaflo Midpipe, Exhaust Technology 3" Mild Steel Single Exit Rotaflo Catback, DBA-5000 2 Piece Slotted Rotors, Project MU BSpec Pads
Rays TE37 18x9.5 +12 in Gunmetallic Fleck with 225/40/18 and 245/40/18 Federal 595SS, Project Kics Titanium Extended Lug Nuts
129RWKW on BP98 Pump
Ripper.
Post by Ripper. » Sat Feb 23, 2013 8:35 pm
viewtopic.php?f=1&t=5556&p=98126#p98126
Just cracked 102C doing a mellow Esplanade cruise. Temp gauge on dash didn't move. :?
calvinp
Post by calvinp » Sat Feb 23, 2013 10:22 pm
102 is easy on days like these.... Even if mellow.
And in the evening too.
Can you just make a note of coolant temp on your S2 during the cruise for us please. Would be interesting to see if max temps are comparable. I hit max of 108 while fanning this morning, at 1030 ish. 37 deg day...
Ripper.
Post by Ripper. » Sat Feb 23, 2013 10:26 pm
calvinp wrote:102 is easy on days like these.... Even if mellow.
No worries, I'll play around with Torque and see if I can get it to record it for me. :D
EDIT:I should be able to log & graph it without an issue.
calvinp
Post by calvinp » Sat Feb 23, 2013 10:58 pm
Thanks heaps.
C
Zerberus
Post by Zerberus » Sat Feb 23, 2013 11:33 pm
I'm in. :)
Unfortunately, someone put a tow-ball into my front bumper last friday.
Still though, keen to tag along.
John
Post by John » Sun Feb 24, 2013 9:39 am
Calvin - it's cooled down here this morning mate, put your jumper on and warm her up.
calvinp
Post by calvinp » Sun Feb 24, 2013 1:45 pm
As a matter of fact, I did take her out :P
Initially only wanted to do the Norton loop, but somehow ended up doing the lobethal loop
Ambient temp 33 deg @ 10 am on the way in... 36 deg on the way back via the free way 30 mins later
Norton leg..max temp 104. no block
Norton to lobethal leg max 106 no block, plenty of air flow. temp, hovered mostly at 95, climbing to 102+ when going up hill in low gears @ high rev
Lobethal to Handorf : stable 94 all the way , not pushing just cruising
Handorf via freeway back to Adelaide 83 to 79 stable, not pushing just cruising
End of free way to home, 15 mins in 36 deg... temp climbed to 99 just as I cruised into the driveway..quite a bit of traffic.
but the freaky thing was... it kept climbing to 102 despite the fans going and car not moving ... weird..
which is exactly the same as what happened yesterday...came back from drive, parked in driveway, idling..and temps continued to climb in the heat.
This car defo does not like bumper to bumper traffic and hot days...
C
Ripper.
Post by Ripper. » Sun Feb 24, 2013 3:34 pm
Pity you didn't join us Calvin. I think the temps you are experiencing are "normal for S2's" I have a feeling that the reading for the ECU is taken from a different point than the S1's. Unfortunately I didn't log temps properly but I was monitoring them.
I peaked to 107C on spirited sections with AC on. With the AC off it between around the 90C-100C mark.
The route got changed last minute. Detoured from Greenhill to Deviation rd, Lobethal road & Norton Summit.
It was a good cruise and a good chance to put some faces to names. A little too warm out, but that just made that first beer more enjoyable :D
Cheers to everyone that braved the heat to make it. Anyone got some pics to post?
